Z-PEEK
Z-PEEK Space Grade Polymer
Materials
Materials
Stainless steel composite 3D printing filament
An innovative metal-polymer 3D printing filament for 17-4 PH stainless steel parts with high hardness and mechanical strength.
BASF Ultrafuse® 17-4 PH is an industrial composite filament compatible with the LPD Plus Zortrax Endureal 3D printer. It has features that allow users to produce metal parts in a safe, easy, and cost-effective way in comparison with Metal Injection Molding or metal machining. The filament contains 80% 17-4 stainless steel particles and 20% of polymer content.
BASF Ultrafuse® 17-4 PH can be used for 3D printing strong metal end-use parts, functional prototypes, elements requiring weather resistance, medical equipment, automotive parts, chemical pipes or valves, elements of tools or fixtures. Printed parts have up to 1004 MPa tensile strength, 764 MPa yield strength, up to 4% elongation at break, and have martensitic (magnetic) microstructure.
3D prints gain their unique properties through the proprietary catalytic debinding and sintering process, outsourced at Elnik Systems GmbH. During this process, 3D printed “green parts” turn into fully metal “brown parts.” As a result you receive magnetizable elements with high corrosion resistance. During the post-processing procedures, BASF Ultrafuse® 17-4 PH models shrink by about 20%. This effect should be taken into account when preparing models for 3D printing.
17-4 PH steel contains more carbon than the 316L grade which makes it significantly stronger and harder. But this higher percentage of carbon also makes it more brittle and prone to corrosion.
It can be used for:
Breakaway support material designed to work with high-performance polymers.
Water-soluble material with fast dissolution rate.
