3D Printers
Zortrax M300 Dual
3D Printers
Zortrax M300 Dual
EAN 5902280825265
Professional large volume dual-extrusion 3D printer.
Device features:
  • LPD Plus dual-extrusion technology
  • 265 x 265 x 300 mm workspace
  • Wi-Fi, USB and Ethernet connectivity
  • Blackout response system
  • Built-in video streaming camera
  • Capacitive displacement sensor
  • Cooling system
  • Filament endstop mechanism
  • Single and dual extrusion modes
  • External materials support
  • Zortrax Speed Mode included
  • Compatible with metallic powder filaments
Lead time: 60 business days
5,500.00 USD
Choose plug type*:
Quantity:
Add to Wish List
Shipping weight: 55.00kg
Description
Large-volume dual-extrusion
Zortrax M300 Dual relies on the dual-extrusion LPD Plus technology to simultaneously print with base and water-soluble support filaments in a large build volume measuring 265x265x300 mm.
Fail-safe 3D printing
The M300 Dual can detect a power outage, jammed filament, and material running out. In each case it pauses the print and saves the exact position of the printing head. This way your work can be resumed from the same spot when the problem has been dealt with.
Interchangeable build-platforms
With a capacitive displacement sensor the M300 Dual can automatically calibrate to work with glass, perforated, or other types of build platforms. This way it’s possible to customize the printer for the project at hand.
Worldwide warranty
Zortrax Speed Mode
Zortrax Speed Mode is a fully free feature available in the latest firmware update for M Series Plus and M300 Dual 3D printers, that allows speeding up your printing even up to 3 times.
Specification
DEVICE
Build volume
265 x 265 x 300 mm (10.4 x 10.4 x 11.8 in)
Nozzle diameter
0.4 mm (0.016 in) - standard
0.6 mm (0.024 in)
Dual, printing with model and support material
Extruder cooling system
Two fans cooling the extruder
Hotend
Dual
Heated
Material Endstop
2 x mechanical
Connectivity
Wi-Fi
USB
Ethernet
Operating system
Android
Processor
Quad Core
Touchscreen
4” IPS 800 x 480
Camera
FILAMENTS
Dedicated for single extrusion
Z-ABS, Z-ASA Pro, Z-ESD, Z-FLEX, Z-GLASS, Z-HIPS, Z-NYLON, Z-PETG, Z-PLA, Z-PLA Pro, Z-ULTRAT, BASF Ultrafuse® PAHT CF15, BASF Ultrafuse® PP GF30, BASF Ultrafuse® PET CF15, 3DXTECH CarbonX PET-G+CF, Kimya PETG Carbon, Nanovia PETG CF, Nanovia PC-ABS V0
Dedicated for dual extrusion
Z-ABS, Z-ASA Pro, Z-ESD, Z-FLEX, Z-NYLON, Z-GLASS, Z-PETG, Z-PLA, Z-PLA Pro, Z-SUPPORT ATP, Z-SUPPORT Premium, Z-ULTRAT, BASF Ultrafuse® PAHT CF15, BASF Ultrafuse® BVOH, Nanovia PC-ABS V0, BASF Ultrafuse® 17-4 PH, BASF Ultrafuse® 316L, BASF Ultrafuse® Support Layer, BASF Ultrafuse® ABS.
External materials
Applicable
Support
Mechanically removed – printed with the same material as the model.
Soluble – printed with a different material than the model
Filament container
Spool
Filament diameter
1.75 mm (0.069 in)
IN THE BOX
3D Printer, Side Covers, Z-SUITE, Starter Kit, Spool of Model Material, Spool of Support Material, 1x Perforated Plate, 1x Glass Plate, 2x Spool Holders, Material Box, USB Memory Stick
PRINTING
Technology
LPD Plus (Layer Plastic Deposition Plus) – advanced technology depositing melted thermoplastics with dissolvable support structures
Layer resolution
150-300 microns (for 0.4 mm / 0.016 in nozzle)
300-500 microns (for 0.6 mm / 0.024 in nozzle)
Minimal wall thickness
450 microns (for 0.4 mm / 0.016 in nozzle)
Platform levelling
Automatic or manual measurement of platform points’ height
TEMPERATURE
310 °C (590 °F)
Maximum platform temperature
105 °C (221 °F)
Ambient operation temperature
20-30 °C (68-86 °F)
Storage temperature
0-35 °C (32-95 °F)
ELECTRICAL
AC Input
110V ~ 5.9 A 50/60 Hz
240V ~ 2.5 A 50/60 Hz
Maximum power consumption
400 W
SOFTWARE
Software bundle
Z-SUITE
Supported input file types
.stl, obj, .dxf, .3mf, .ply
Supported operating system
Mac OS Catalina and newer versions
Windows 10 and newer versions
ADDITIONAL INFORMATION
All information contained in this brochure and specification is subject to change without notice. Each delivered printer may have worked up to 90 hours during the quality control test prints.
Materials & Accessories
