Materials
Z-SUPPORT ATP 130
Materials
Z-SUPPORT ATP 130
EAN:
5902280827627
Z-SUPPORT ATP 130 is a soluble support filament which works with high-temp filaments such as Z-PEEK, VICTREX AM™ 200 FIL (PAEK) and Z-ULTRAT Plus exclusively on Zortrax Endureal.
  • Container: Spool
  • Diameter: 1.75 mm
  • Net weight: 750 g ± 5%
  • Dedicated for:
Lead time: 30 business days
230.00 USD
Take 6 and pay for 3! *
Use coupon: 3+3
Colors:
Out of stock
Add to Wish List
Shipping weight: 1.25kg
Description
Z-SUPPORT ATP 130 is a soluble support filament with a higher glass transition temperature than Z-SUPPORT ATP. It works with Z-PEEK, VICTREX AM™ 200 FIL (PAEK) and Z-ULTRAT Plus exclusively on Zortrax Endureal. The filament does not support in pure water, but in a mild alkaline solution of water and Z-SUPPORT ATP Activator. Thanks to that, the filament is less susceptible to draw moisture from air, which is reflected in a consistent printing quality it can bring. Models printed with Z-SUPPORT ATP 130 should be post-processed in a heated, stirred bath at a temperature of 80° C.
Applications:
  • High temperature 3D printing
  • Models with complex geometries
  • Models with interlocked elements
  • Movable mechanisms, such as gears or bearing
Main features:
  • High stability during the printing process
  • High melting rate
  • Long shelf life
Protect from water, moisture and direct sunlight.
Store in a dry room, in closed and air-tight packaging with desiccant when not in use.
Store at ambient temperatures. Avoid all sources of ignition.
Related Materials
