Post-processing
Zortrax Cleaning Station
Post-processing
EAN 5902280827610
Zortrax Cleaning Station is a professional post-processing device designed to remove uncured resin from the surfaces of printed parts. The device uses an impeller-based system to clean 3D prints, which reduces the risk of damaging details. The Cleaning Station supports the most popular resin 3D printing technologies – UV LCD, DLP, and SLA.
Lead time: up to 60 business days.
Device features:
  • 300 x 210 x 270 mm workspace;
  • tank capacity 18l;
  • two mechanical filters: polypropylene cartridge (1 micron) and stainless mesh cartridge with UV lighting (150 microns);
  • excessive cleaning fluid level sensor;
  • flow meter preventing operation without the cleaning fluid in the system.
Lead time: 2-3 Days
22,908.75 PLN
Included VAT: 4,283.75 PLN
Add to Wish List
Shipping weight: 90.00kg
Description
Zortrax Cleaning Station is a post-processing device made to remove excessive, uncured resin from models' surfaces. It is a standalone device that can be used to support all types of resin 3D printers available on the market. It’s dedicated to post-process even most professional and demanding resins (quality approved by BASF Forward AM and Henkel/Loctite).
Supports most popular resin 3D printing technologies: UV LCD, DLP, and SLA
The impeller-based cleaning system
The impeller reduces the risk of damaging precise, fragile prints. The entire cleaning process lasts for about 5 minutes and is fully automated. When it is done, the top cover opens up and the build platform with clean prints is moved out of the cleaning fluid.
Filtering system
Due to filters constantly working in the Zortrax Cleaning Station, the isopropyl alcohol can be reused in multiple cleaning sessions.
Compatible with Inkspire 2
The build platform holder in the Zortrax Cleaning Station is compatible with the Zortrax Inkspire 2 build platform which enables placing the printed models in the device without touching them.
Ready to use right away
Zortrax Cleaning Station does not need calibration before first use.
Worldwide warranty
Specification
DEVICE
Working area dimensions
300 x 210 x 270 mm (11.8 x 8.27 x 10.6 in)
Tank capacity
18 l
Filters
Display/control panel
touch control panel
Security
excessive cleaning fluid level sensor and flow meter preventing operation without the cleaning fluid in the system
Device (W x D x H)
460 x 460 x 490 mm (18.1 x 18.1 x 19.3 in)
Weight - without IPA
40 kg (88.2 lb)
Weight - with IPA (full tank)
around 60 kg (132 lb)
ELECTRICAL
AC Input
100 - 240 V AC 4 A 50/60 Hz
Maximum power consumption
48 W
IN THE BOX
Zortrax Cleaning Station, a metal basket for 3D prints’ cleaning, a holder for attaching the Inkspire 2 platform, Starter Kit
ADDITIONAL INFORMATION
All information contained in this brochure and specification is subject to change without notice. Each delivered device may have worked up to 20 hours during the quality control test.
