3D Printers
3D Printers
Lead time:
0.00 PLN
Included VAT: 0.00 PLN
Add to Wish List
Shipping weight: 0.00
Description
Specification
3D PRINTER
DEVICE
Build volume
265 x 265 x 300 mm (10.4 x 10.4 x 11.8 in)
Nozzle diameter
0.4 mm (0.016 in) - standard
0.6 mm (0.024 in)
Dual, printing with model and support material
Extruder cooling system
Two fans cooling the extruder
Hotend
Dual
Heated
Material Endstop
2 x mechanical
Connectivity
Wi-Fi
USB
Ethernet
Operating system
Android
Processor
Quad Core
Touchscreen
4” IPS 800 x 480
Camera
PRINTING
Technology
LPD Plus (Layer Plastic Deposition Plus) – advanced technology depositing melted thermoplastics with dissolvable support structures
Layer resolution
150-300 microns (for 0.4 mm / 0.016 in nozzle)
300-500 microns (for 0.6 mm / 0.024 in nozzle)
Minimal wall thickness
450 microns (for 0.4 mm / 0.016 in nozzle)
Platform levelling
Automatic or manual measurement of platform points’ height
FILAMENTS
Dedicated for single extrusion
Z-ABS, Z-ASA Pro, Z-ESD, Z-FLEX, Z-GLASS, Z-HIPS, Z-NYLON, Z-PETG, Z-PLA, Z-PLA Pro, Z-ULTRAT, BASF Ultrafuse® PAHT CF15, BASF Ultrafuse® PP GF30, BASF Ultrafuse® PET CF15, 3DXTECH CarbonX PET-G+CF, Kimya PETG Carbon, Nanovia PETG CF, Nanovia PC-ABS V0
Dedicated for dual extrusion
Z-ABS, Z-ASA Pro, Z-ESD, Z-FLEX, Z-NYLON, Z-GLASS, Z-PETG, Z-PLA, Z-PLA Pro, Z-SUPPORT ATP, Z-SUPPORT Premium, Z-ULTRAT, BASF Ultrafuse® PAHT CF15, BASF Ultrafuse® BVOH, Nanovia PC-ABS V0, BASF Ultrafuse® 17-4 PH, BASF Ultrafuse® 316L, BASF Ultrafuse® Support Layer, BASF Ultrafuse® ABS.
External materials
Applicable
Support
Mechanically removed – printed with the same material as the model.
Soluble – printed with a different material than the model
Filament container
Spool
Filament diameter
1.75 mm (0.069 in)
TEMPERATURE
310 °C (590 °F)
Maximum platform temperature
105 °C (221 °F)
Ambient operation temperature
20-30 °C (68-86 °F)
Storage temperature
0-35 °C (32-95 °F)
ELECTRICAL
AC Input
110V ~ 5.9 A 50/60 Hz
240V ~ 2.5 A 50/60 Hz
Maximum power consumption
400 W
SOFTWARE
Software bundle
Z-SUITE
Supported input file types
.stl, obj, .dxf, .3mf, .ply
Supported operating system
Mac OS Catalina and newer versions
Windows 10 and newer versions
IN THE BOX
3D Printer, Side Covers, Z-SUITE, Starter Kit, Spool of Model Material, Spool of Support Material, 1x Perforated Plate, 1x Glass Plate, 2x Spool Holders, Material Box, USB Memory Stick
ADDITIONAL INFORMATION
Each delivered printer may have worked up to 90 hours during the quality control test prints.
DSS Station
MECHANICAL
Maximum working temperature
75 °C (167 °F)
Maximum rotational speed
220 rpm
ELECTRICAL
AC input
110V ~ 9 A 50/60 Hz
240V ~ 4.2 A 50/60 Hz
1000 W
External dimensions (W x D x H)
235 x 238 x 295 mm (9.2 x 9.4 x 11.6 in)
Internal dimensions
188 x 188 x 199 mm (7.4 x 7.4 x 7.8 in)
Working volume
6 l (202.9 fl oz)
Device weight
8.4 kg (18.5 lb)
IN THE BOX
DSS Station, rising basket, rubber gloves, brush, drain pipe, power cable, quick start guide
