3D Printers
3D Printers
- The XY resolution is 50x50 microns.
- Calibrates build platform semi-automatically.
- The minimal layer height is 25 microns.
- Has a build-in carbon filter.
- Offers serial production capability.
- External 405 nm resins are supported.
- External slicing software is supported.
- .zcodex and .cws file formats are supported.
- Workspace measures 74x132x175 mm.
- Has Wi-Fi and ethernet connectivity.
- Has an intuitive touch interface.
Lead time:
0.00 USD
Shipping weight: 0.00
Description
Specification
Device features
Build volume
74 x 132 x 175 mm (2.9 x 5.2 x 6.9 in)
Platform calibration
Semi-automatic
Support
Mechanically removed - printed with the same material as the model
Light source
Integrated UV lamp (wavelength 405 nm)
Connectivity
Wi-Fi, Ethernet, USB
Operating system
Android
Processor
Quad Core
Touchscreen
4'' IPS 800 x 480
Available materials
Zortrax Resin BASIC, RAYDENT Crown&Bridge Resin, RAYDENT Surgical Guide Resin, BLUECAST X5, BLUECAST X10, BLUECAST ORIGINAL, Druckwege Type D Dental Model Resin
External materials
Applicable
In the box
3D Printer, Z-SUITE, Starter Kit, Zortrax Photopolymer Resin BASIC (500 ml)
Weight and physical dimensions
Device (W x D x H)
210 x 210 x 420 mm (8.3 x 8.3 x 16.5 in)
Shipping box
315 x 312 x 530 mm (12.4 x 12.3 x 20.9 in)
Net weight
6.2 kg (13.7 lb)
Device weight
10.1 kg (22.3 lb)
Shipping weight
10.5 kg (23.1 lb)
Software
Software bundle
Z-SUITE 2
Supported file types
.stl, .obj, .dxf, .3mf, .ply
Supported formats
.cws, .zcodex, .sl1, .zip
Supported operating systems
Mac OS Mojave** / Windows 7 and newer versions
Printing
Technology
UV LCD
Pixel size
50 microns (0.05 mm)
Layer thickness
25, 50, 100 microns
Print speed
20-36 mm/h
Ambient operation temperature
20-30˚ C (68-86˚ F)
Storage temperature
0-35˚ C (32-95˚ F)
AC input
110 V ~ 1.4 A 50/60 Hz 240 V ~ 0.85A 50/60 Hz
Power supply parameters
12 V DC @ 6 A, 50 W
Maximum power consumption
75 W
In the box
Zortrax Inkspire 3D Printer
Zortrax Ultrasonic Cleaner
UV Resin
USB Drive
Wi-Fi Module
Z-SUITE Software License and Quick Start Guide
Cleaning Box
FEP Film
Starter Kit
One-year warranty*
Additional information
All information contained in this brochure and specification is subject to change without notice.
Copyrights © 2025 Zortrax. All rights reserved
