Parts & Accessories
Zortrax HEPA Cover
Parts & Accessories
Zortrax HEPA Cover
EAN 5902280823421
A filtering device for M200 and M200 Plus.
Device features:
  • Compatible with Zortrax M200 and M200 Plus 3D printers
  • Maintains stable temperature inside the printing chamber to reduce warping of ABS-based materials
  • Carbon filter eliminates unpleasant smells
  • HEPA filter catches over 99% of 3D printing emissions, including ultra fine particles
  • Electric fan with regulated speed
  • Dimensions: 426x357x230 mm
  • Dedicated for:
    Zortrax M200
    Zortrax M200 Plus
219.00 USD
Quantity:
Add to Wish List
Shipping weight: 7.50kg
Description
Quality of Your Prints Covered
Zortrax HEPA Cover is a filtering device compatible with Zortrax M200 and Zortrax M200 Plus 3D printers. It keeps the temperature stable inside the printing chamber to reduce warping of ABS-based materials. Built-in carbon filter gets rid of unpleasant odors released in the 3D printing process, while HEPA filter catches over 99% of 3D printing emissions, including ultra fine particles.
Zortrax HEPA Cover solves following issues
What's in the box
  • Zortrax HEPA Cover
  • Filter Module (Electric Fan with Regulated Speed, HEPA Filter, Carbon Filter)
  • Power Supply Unit
  • Front Door
  • User's Manual
Before the first use, you need to follow a few simple steps to set your Zortrax HEPA Cover up and properly attach it onto your Zortrax M200 or M200 Plus 3D printer.
Specification
Without filtering module (W x D x H)
368 x 357 x 230 mm (14.5 x 14.1 x 9.1 in)
With filtering module (W x D x H)
426 x 357 x 230 mm (16.8 x 14.1 x 9.1 in)
Box dimensions
405 x 380 x 255 mm (15.9 x 15 x 10 in)
Device weight
1.95 kg (4.3 lb)
Total weight of the box
3,35 kg (7.4 Ibs)
IN THE BOX
Device, Power Supply Unit, Filtering Module with HEPA and Carbon Filters
FILTRATION
Odor reduction filter
Carbon
Particle reduction filter
HEPA
Filtration efficiency
99.5%
ELECTRICAL
AC input
100 - 240 V ~ 0.7 A 50/60 Hz
Power supply parameters
12 V DC, 0.5 A (min)
Maximum power consumption
6 W
* Dimensions of an assembled, ready to use device.
Related Accessories
