Post-processing
Zortrax Apoller SVS Device
Post-processing
EAN 5902280824299
A smart vapor smoothing device.
Device features:
  • 300x250x250 mm smoothing chamber
  • Zortrax SVS technology
  • MEK and acetone compatibility
  • Intuitive touch interface
  • Wi-Fi and Ethernet connectivity
  • Compatibility with Z-ABS, Z-ULTRAT, Z-ULTRAT Plus, Z-ASA Pro, and Z-HIPS
  • Compatibility with external materials including ABS, ASA, and HIPS
  • Advanced vapor circulation system
Lead time: 60 business days
8,617.09 USD
Choose plug type*:
Quantity:
Add to Wish List
Shipping weight: 90.00kg
Description
A smart and safe device for automated vapor smoothing
Zortrax Apoller is a smart vapor smoothing device that automatically removes visible layering from FDM 3D prints. It works works with both acetone and MEK. The smoothing process is fully automated and run by proprietary algorithms managing temperature, pressure, and concentration of solvent's vapors at all times. First, the model has to be placed inside the smoothing chamber. Once this is done, the chamber is heated enough to vaporize the solvent deposited in a sink below the glass tray. Vapors are then circulated spiraling upwards to evenly cover the model. Solvent's vapors condensate on surfaces leaving them with a glossy or mat finish, depending on the filament used. Finally, Zortrax Apoller dries the prints out to make them ready to use straight out of the chamber. Combined weekly output of 4 typical FDM 3D printers can be automatically smoothed within one day.
Worldwide warranty
Compatible filaments: ABS, ASA, HIPS
Compatible solvents: Acetone, Butanone (MEK)
Compatible Zortrax filaments: Z-ABS, Z-HIPS, Z-ULTRAT, Z-ULTRAT Plus, Z-ASA Pro
Specification
DEVICE
Build volume
300 x 250 x 250 mm (11.8 x 9.8 x 9.8 in)
Connectivity
Wi-Fi
USB
Ethernet
Operating system
Android
Processor
Quad Core
Touchscreen
4” IPS 800 x 480
Solvent compatibility*
Aceton, MEK
Zortrax compatible materials
Z-ABS
Z-ASA Pro
Z-HIPS
Z-ULTRAT
Z-ULTRAT Plus
External compatible materials
ABS
ASA
HIPS
Device (W x D x H)
671 x 396 x 388 mm (26.4 x 15.6 x 15.3 in)
Internal dimensions
340 x 270 x 260 mm (13.4 x 10.6 x 10.2 in)
Device weight
30 kg (66 lb)
IN THE BOX
Device, Starter Kit
PROCESS
Maximum working temperature
90 °C (194 °F)
Minimum working temperature
-20 °C (-4 °F)
Minimum gauge working pressure
-0.6 bar
Ambient operation temperature
15-30 °C (59-86 °F)
Storage temperature
0-35 °C (32-95 °F)
ELECTRICAL
AC Input
110 V ~ 13.6 A 50/60 Hz
240 V ~ 6.3 A 50/60 Hz
Power supply parameters
24 V DC @ 21 A, 500 W
Maximum power consumption
1500 W
ADDITIONAL INFORMATION
All information contained in this brochure and specification is subject to change without notice. Each delivered printer may have worked up to 60 hours during the quality control test prints.
* Only pure acetone or MEK are supported and safe to use. Using other solvents may be dangerous and should not be attempted.
