3D Printers
Zortrax M300 Plus & HEPA Cover
3D Printers
M300 Plus 3D Printer and Zortrax HEPA Cover.
A bundle of a large volume desktop 3D printer and its dedicated filtering device. Side Covers included.
Zortrax M300 Plus main features:
  • LPD technology
  • 300 x 300 x 300 mm workspace
  • Wi-Fi, USB, and Ethernet connectivity
  • Blackout Response System
  • Built-in camera
  • Intuitive LCD touchscreen
  • Optical endstops for the X and Y axes
  • Double fan and extruder cooling
  • Filament endstop mechanism
  • Flex-type materials compatibility
  • External materials support
  • Zortrax Speed Mode included
Zortrax HEPA Cover features:
  • Maintains stable temperature inside the printing chamber to reduce warping of ABS-based materials
  • Carbon filter eliminates unpleasant smells
  • HEPA filter catches over 99% of 3D printing emissions, including ultra fine particles
  • Electric fan with regulated speed
Lead time: 60 business days
4,600.00 USD
Add to Wish List
Shipping weight: 76.00kg
Description
Zortrax M300 Plus with Zortrax HEPA Cover
Zortrax HEPA Cover is a filtering device compatible with Zortrax M300 Plus large volume wireless 3D printer. Zortrax M300 Plus has one of the biggest build volumes among Plug & Play devices and can 3D print large models in one go. Equipped with Wi-Fi and Ethernet connectivity it can be used to create a network of reliable 3D printers. With Zortrax HEPA Cover attached, it's possible to maintain higher temperatures inside the M300 Plus’ printing chamber which significantly reduces shrinkage of ABS-based materials. HEPA filters catch over 99% of 3D printing emissions, including ultra fine particles, while carbon filters work to reduce unpleasant smells to ensure safe and smooth operation of a 3D printing farm.
Worldwide warranty
Zortrax Speed Mode
Zortrax Speed Mode is a fully free feature available in the latest firmware update for M Series Plus and M300 Dual 3D printers, that allows speeding up your printing even up to 3 times.
Specification
3D PRINTING
DEVICE
Build volume
300 x 300 x 300 mm (11.8 x 11.8 x 11.8 in)
Nozzle diameter
0.4 mm (0.016 in) – standard / 0.3 mm (0.012 in) / 0.6 mm (0.024 in)
Single (compatible with demanding materials like TPU or nylon)
Extruder cooling system
Radial fan cooling the extruder block
Hotend
Single, V3
Heated
Material endstop
Mechanical
Connectivity
Wi-Fi, Ethernet, USB
Operating system
Android
Processor
Quad Core
Touchscreen
4” IPS 800 x 480
Camera
FILAMENTS
Available Filaments
Z-ABS, Z-ABS 2, Z-ASA Pro, Z-ESD, Z-FLEX, Z-GLASS, Z-HIPS, Z-NYLON, Z-PCABS, Z-PETG, Z-PLA, Z-PLA Pro, Z-ULTRAT, Nanovia PC-ABS V0, BASF Ultrafuse® ABS
External materials
Applicable
Support
Mechanically removed – printed with the same material as the model
Filament container
Spool
Filament diameter
1.75 mm (0.069 in)
PRINTING
Technology
LPD (Layer Plastic Deposition) – depositing melted material layer by layer onto the build platform
Layer resolution
90-140 microns (for 0.3 mm / 0.012 in nozzle), 90-390 microns (for 0.4 mm / 0.016 in nozzle), 300-400 microns (for 0.6 mm / 0.024 in nozzle)
Minimal wall thickness
450 microns (for 0.4 mm / 0.016 in nozzle)
Platform levelling
Automatic measurement of platform points’ height
TEMPERATURE
290 °C (554 °F)
Maximum platform temperature
105 °C (221 °F)
Ambient operation temperature
20-30 °C (68-86 °F)
Storage temperature
0-35 °C (32-95 °F)
ELECTRICAL
AC Input
110V ~ 5.9 A 50/60 Hz, 240V ~ 2.5 A 50/60 Hz
Maximum power consumption
360 W
SOFTWARE
Software bundle
Z-SUITE
Supported input file types
.stl, obj, .dxf, .3mf, .ply
Supported operating system
Mac OS Catalina and newer versions / Windows 10 and newer versions
IN THE BOX
3D Printer, Hotend V3, Side Covers, Z-SUITE, Starter Kit, 2x Material Spool, Spool Holder, USB Memory Stick
ADDITIONAL INFORMATION
Each delivered printer may have worked up to 90 hours during the quality control test prints.
All information contained in this brochure and specification is subject to change without notice.
HEPA COVER
ELECTRICAL
AC input
100 - 240 V ~ 0.7 A 50/60 Hz
Power supply parameters
12 V DC, 0.5 A (min)
6 W
FILTRATION
Odor reduction filter
Carbon
Particle reduction filter
HEPA
Filtration efficiency
99.5%
Without filtering module (W x D x H)
496 x 483 x 280 mm (19.5 x 19.1 x 11 in)
With filtering module (W x D x H)
545 x 483 x 280 mm (21.5 x 19.1 x 11 in)
Box dimensions
565 x 550 x 335 mm (22.2 x 21.7 x 13.2 in)
Device weight
2.55 kg (5.6 lb)
Total weight of the box
4,8 kg (10.6 Ibs)
IN THE BOX
Device, Power Supply Unit, Filtering Module with HEPA and Carbon Filters
*Since the release of macOS Big Sur, we’ve been developing Z-SUITE’s best possible operation on this system and all its future updates. The available version is fully functional, however minor bugs may occur.
