3D Printers
3D Printers
Lead time:
0.00 USD
Shipping weight: 0.00
Description
Specification
3D PRINTING
DEVICE
Build volume
200 x 200 x 180 mm (7.9 x 7.9 x 7.1 in)
Nozzle diameter
0.4 mm (0.016 in) – standard
0.3 mm (0.012 in)
0.6 mm (0.024 in)
0.3 mm (0.012 in)
0.6 mm (0.024 in)
Single (compatible with demanding materials like TPU or nylon)
Extruder cooling system
Radial fan cooling the extruder block
Hotend
Single, V3
Heated
Material endstop
Mechanical
Connectivity
Wi-Fi
USB
Ethernet
USB
Ethernet
Operating system
Android
Processor
Quad Core
Touchscreen
4” IPS 800 x 480
Camera
FILAMENTS
Available Filaments
Z-ABS, Z-ABS 2, Z-ASA Pro, Z-ESD, Z-FLEX, Z-GLASS, Z-HIPS, Z-NYLON, Z-PCABS, Z-PETG, Z-PLA, Z-PLA Pro, Z-ULTRAT, Nanovia PC-ABS V0, BASF Ultrafuse® ABS
External materials
Applicable
Support
Mechanically removed – printed with the same material as the model
Filament container
Spool
Filament diameter
1.75 mm (0.069 in)
PRINTING
Technology
LPD (Layer Plastic Deposition) – depositing melted material layer by layer onto the build platform
Layer resolution
90-140 microns (for 0.3 mm / 0.012 in nozzle)
90-390 microns (for 0.4 mm / 0.016 in nozzle)
300-400 microns (for 0.6 mm / 0.024 in nozzle)
Minimal wall thickness
450 microns (for 0.4 mm / 0.016 in nozzle)
Platform levelling
Automatic or manual measurement of platform points’ height
TEMPERATURE
290 °C (554 °F)
Maximum platform temperature
105 °C (221 °F)
Ambient operation temperature
20-30 °C (68-86 °F)
Storage temperature
0-35 °C (32-95 °F)
ELECTRICAL
AC Input
110V ~ 5.9 A 50/60 Hz
240V ~ 2.5 A 50/60 Hz
Maximum power consumption
320 W
SOFTWARE
Software bundle
Z-SUITE
Supported input file types
.stl, obj, .dxf, .3mf, .ply
Supported operating system
Mac OS Catalina and newer versions
Windows 10 and newer versions
IN THE BOX
3D Printer, Hotend V3, Side Covers, Z-SUITE, Starter Kit, Material Spool, Spool Holder, USB Memory Stick
ADDITIONAL INFORMATION
All information contained in this brochure and specification is subject to change without notice. Each delivered printer may have worked up to 90 hours during the quality control test prints.
HEPA COVER
ELECTRICAL
AC input
100 - 240 V ~ 0.7 A 50/60 Hz
Power supply parameters
12 V DC, 0.5 A (min)
6 W
FILTRATION
Odor reduction filter
Carbon
Particle reduction filter
HEPA
Filtration efficiency
99.5%
Without filtering module (W x D x H)
368 x 357 x 230 mm (14.5 x 14.1 x 9.1 in)
With filtering module (W x D x H)
426 x 357 x 230 mm (16.8 x 14.1 x 9.1 in)
Box dimensions
405 x 380 x 255 mm (15.9 x 15 x 10 in)
Device weight
1.95 kg (4.3 lb)
Total weight of the box
3,35 kg (7.4 Ibs)
IN THE BOX
Device, Power Supply Unit, Filtering Module with HEPA and Carbon Filters
Copyrights © 2024 Zortrax. All rights reserved
